sn0wchyld said:rui_fujino said:I don't know if what you're planning would work with balancer...but I really think you should make 5 of 4s2p then series them after...I have not had experience to explain why it should be this way but I do know we had quite big discussion on this couple years back.
it would be a bit of a pain if your balancing your pack every charge, but with bulk charging it works a treat, and you can always balance with a bm. afterall, after paralleling the packs via the balance leads, you've done the exact smae thing as paralleling them via the discharge leads.
I plan on Bulk Charging 90% of the time. Like so:
The remaining 10% will be either one of the two forms of balancing: (a) traditional method of using a balance charger to charge the pack via the main leads and then letting cells at optimum voltage discharge via the balance leads until the lagging cell reaches optimum voltage -OR- (b) using Ykicks method of finding a lagging cell and hooking into it directly via the balance lead to bring it up to optimum voltage [http://endless-sphere.com/forums/viewtopic.php?f=6&t=41331&start=30#p655336]
