Ecooter Controller wiring diagram.
remar
100 µW
Valenzuela
Does anyone can help me regarding on wiring diagram for this controller I've looked over the internet and I cant find anything.
Please do help me with this controller do you guys has a wiring description for this controller help me pleasee!
Low chances on finding a wiring diagram for any cheap Chinese motor controller. You'd have better luck asking how to hook it up, if that's what you're ultimately trying to do.
Yeah I'm trying to hooking on it up I already found the ignition wire plus the park mode but I cant seem to find the throttle line
Battery input and motor phase output are pretty obvious. The connector at the bottom of the pic is the hall sensor connector to the motor.
My guess is that the longer connector on the right has the 5v and ground, plus other functions like throttle (maybe green?), on/off, etc. I'd try to identify/confirm the 5v before other testing.
Ill try that later Ill update you once I hooked it up
I’m looking for a way to reset or re flash mine. I’ve got an E16 error as it got corrupt when updating firmware. Any help on this would be appreciated.
