cassschr1
Doc made his adjustable. They come with the voltage you tell them to set it at. One choice, per unit.
gensem said:Doc,
So you think I can safely order the 2kw charger configured to 48s lipo (201.6v) 9amp and change it to.. lets say 24s (100,8v) 18 amps? or even less 50,4v 36 amps?
Thanks
cassschr1 said:Doc made his adjustable. They come with the voltage you tell them to set it at. One choice, per unit.
NeilP said:Doc
In this picture you show the wires coming in for voltage sense...where exactly do they go on the board..My charger arrived today, and want to start modding it.
Also, the pot for current limiting..is it just wired with two wires?
My pots are covered in white silicon, so i can't see the labels on the board for W104 etc...could you maybe make a drawing or indicate on the picture for me with them labelled
Another thing..do you have a part number or spec for that three pin diode you used for output protection? I have my charger set from fctory to 142.8 volt 12 amps...but want to take it down to 100volt..maybe 84
NeilP said:Hey Mega...you want three of these boards! a 6kW portable charger on the bike!!. How long are you looking for a re-charge? 10 -15 minutes from full discharge?
megacycle said:miss the nightlife, silver service, duty frees and yes dare say the ex.
Doctorbass said:I strongly recommend you to buy one that is like 25% more voltage than you plan on using. Ex if you want 24s lipo, than ask for a charger for a voltage for 30s
The reason is that i ordered one for 100.8V ( 24s lipo) and the max adjustable voltage i have is 105V. If i try to modify the resistor near the pot ( the one that set the max range), it dont want to go over 105V and make a strange szzzz sound indicating that it become instable( not good...).
They call them 2000W but generally, the voltage and current they offer is all product that give around 1500W.. just like mine that they wanted to set to 15A max instead of 20A... I dont care about 120V ac at 20A draw or 240V at 10A draw.. but they seem to not accept seting it for output power over 1500W.
I succeded to boose the current to up to 22A ( diring short time) at 100V... but i dont feel confident about keeping that seting continusly...
Also.. if you want to activate the output without the need of having the voltage of a battery detected, you can just connect a resistor across the relay N-O contact... 1000ohm work well and than the relay activate so you have voltage at the output.
About the max voltage they set for you i thing that the component of all teh version of that charger vary depending of the voltage you want. I think that for a given range of voltage or power, they select components according to that... in other words, i thing they have let say 4 version of charger . one that they cah adjust from 12 to 36V with the capacitor and other parts optimized for that range of voltage and current , another for 36 to 72.. adn another for 72 to 105... , another for 105 to 200... etc... due to the higher number of parallel parts for the high current version etc...
That might be the reason why mine can't go over 105V... maibe the PWM is reaching 100% at that value... so That's why i recommand you to select a voltage little higher than what you plan to use... so by that way you will be able to readjust it to your desired voltage.. and the current limit should not be too affected if you use 25% more..
Doc
rolf_w said:1 = W503 ; turn CW to increase V_out ; range 57V - 116.5V if W4011 set to max V_out
1a = W502 ; is for ??? (not mounted)
2 = W501 ; is for LED lamp indicator adjustment
3 = ?W401? ; is for current adjustment (can't see the label)
4 = W402 ; is also for current adjustment ( probably the fine or coarse)
5 = W4011 ; turn CCW to increase V_out ; shifts the range of W503, kind of offset?; I tried W503 ranges for a number of fixed W4011 positions e.g. 47.0-105.7V, 42.5 - 96.0, 32.5 - 73.5, 28.0 -63.5; I was able to trim down V_out minimum to 2V!
6 = ?
7 = ?
rolf
