gwhy!
The 800lb spring I have at the mo do give me my required sag and also the gap between the coils do not hit before the end of the shock stroke but this spring is where it needs to be before you start adjusting ,so ideally it needs to be around a 1000lb spring, I might get away with using this but My next concern as regards my bicycle rear shock is the damping may not be strong enough which will be even more of a problem but on a plus note the rebound appears to be fine . I am using a tough shock FDR ( it is a budget shock and very good for the price for what it is ). I also have a fox shock rear body but it has no mounting hardware so I have just ordered some bearings so I can try this shock to see if the damping is any better, fingers crossed.
