Lenk42602
Swing arm pivot tube is welded in. Reassembled pivot tube with bearings, axle and mock up.
this pic shows how tight everything gets when you have to screw with pedal -chains and pivots on rear suspension bicycles. just about 10-12mm from the chain ring to the drive-side pivot axle clamp..
thar she sits...
So now comes the joining of the two halves of the bike. The swing arm clamps get welded into the main frame. Then she needs the all of the seams finish welded. Mike, you're on soon baby..... Once that phase is over, then shock mounts get fab'd and welded in, then seat post/seat post supports.
Len
thar she sits...
Len
