Try around 75% to 80% pole coverage. Also, try adjusting the slot opening width. This often goes the opposite way to what you might expect. Sometimes, widening the slot opening will reduce torque ripple.F4P said:So overall i have only 87,5% magnet area and the same flux and torque. ...but torque ripple is aweful now,
Miles said:Try around 75% to 80% pole coverage. Also, try adjusting the slot opening width. This often goes the opposite way to what you might expect. Sometimes, widening the slot opening will reduce torque ripple.F4P said:So overall i have only 87,5% magnet area and the same flux and torque. ...but torque ripple is aweful now,
Radius?F4P said:Has someone a idea how to scale up my 42pole36slot motor concept to a outer radius of 400mm? .
Miles said:Radius?F4P said:Has someone a idea how to scale up my 42pole36slot motor concept to a outer radius of 400mm? .
liveforphysics said:F4P- Miles is offering you sage-level advice for improving your motor design.
You will find it's effortless to make the torque, it's simply a matter of making a big radius and adequate width, there is no skill required to simply design a motor that has good torque/power potential.
Miles is trying to show you what makes a good motor from another POS motor design. It's in the BEMF waveform being sinus, and hence the minimization of harmonic content and torque ripple as a result.
It is already a well proven technique to take a big radius stator and make the torque/power you want. If you wish to also make your motor design efficient and controllable and smooth and low-parasitic harmonics etc, I advise you directly follow any advice Miles so kindly takes the time to offer you.
F4P said:[pre]torque 0,7285 1,457 2,1855 2,914 4,371 5,828 7,285 8,74 10,199 11,65 13,113 14,57
eta conductor losses 0,183 0,736 1,655 2,943 6,622 11,77 18,39 26,49 36,05 47,09 59,6 73,57
iron losses rpm / Current 1 2 3 4 6 8 10 12 14 16 18 20
0,77 100 87,65 90,48 90,01 88,78 85,74 82,6 79,56 76,69 73,99 71,46 69,08 66,86
1,71 200 87,60 91,98 92,64 92,37 90,90 88,95 86,82 84,60 82,32 80,01 77,68 75,33
2,83 300 86,82 92,22 93,47 93,70 93,12 92,03 90,73 89,33 87,87 86,37 84,85 83,31
4,13 400 85,79 92,02 93,68 94,20 94,13 93,49 92,62 91,64 90,59 89,51 88,40 87,27
5,53 500 84,95 91,79 93,72 94,45 94,69 94,33 93,73 93,00 92,21 91,38 90,51 89,63
7,00 600 84,22 91,55 93,70 94,57 95,04 94,88 94,45 93,90 93,28 92,61 91,92 91,20
8,56 700 83,52 91,30 93,62 94,61 95,26 95,24 4,95 94,53 94,03 93,49 92,91 92,31
10,2 800 82,78 91,00 93,50 94,60 95,39 95,49 95,31 94,98 94,58 94,13 93,64 93,13
12,1 900 81,96 90,65 93,32 94,52 95,45 95,65 95,56 95,32 94,99 94,61 94,20 93,76
14,1 1.000 81,03 90,22 93,08 94,39 95,46 95,75 95,73 95,56 95,30 94,98 94,63 94,25
16,4 1.100 80,04 89,77 92,81 94,23 95,42 95,80 95,85 95,74 95,53 95,27 94,97 94,64
18,7 1.200 79,19 89,37 92,58 94,08 95,39 95,84 95,95 95,88 95,73 95,51 95,25 94,96[/pre]
the red marked eta values are the ones i expect in the typical cruise mode.
