Miles said:https://www.emetor.com/blog/post/emetor-crossroads/
Try again now...... https://www.emetor.com/blog/post/release-2013-12-16-faster-load-simulations-certain-machines-negative-magnetic-periodicity/ My loaded 24t 20p sims now run again, and in about a quarter of the time/cost.bearing said:I didn't know about an airgap meshing change. But sims that used to run, doesn't anymore, so that makes sense.
Miles said:For 24t 22p design, the simulation still fails.
Indeed, it does Thanks Stephan!emetor said:I have slightly modified the Emetor solver, so there is a chance that your 24t 22p design might run now.
It made for an interesting comparison... The only downside to 24t 22p is the single winding symmetry - without allowing for that, torque ripple seems to be substantially less for 22p.....emetor said:BTW: 24t 22p is a rather promising pole-slot combination with a higher winding factor than the 24t 20p design.
