Bluefang
Hello,
I have a project i am working through to promote to my work. We currently have a out door pool that is sitting at 16-18 degrees Celsius during winter. Its meant to be a Luxury hotel with a heated feature pool at 26 degrees. We currently use a gas heater to run everything and even between all 8 of them working its got no hope of keeping the pool at anything more then 22 C when working perfectly which they are not atm. The major problem we have with the pool is that its surface area is huge, its not very deep and the worst shape to try and use a heat blanket. 65mx15mx1.6m is the rough shape.
One of the ways i have been thinking to heat the pool is a massive Evacuated tube collector array, we have a large flat thick concrete roof due to been only a short hotel with some large ground space. The hotel is on the gold coast which has sun most days of winter with a avg night temp of ~12 and day time 22+ so i think it would be possible fairly easily to keep the pool heated over winter. Bonus is during summer with the high demand on the air conditioning system we can use the hot water from the collectors to feed a adsorption chiller to pre-chill the large AC units on the roof next to where the collectors would be placed along with also running all of the hot water units for the hotel.
The part thats causing me worry is getting the hot water for the pool to the pool heat exchanger system already in the basement of the hotel. We have some unused 50mm PCV pipes that were orriginaly used to run water to the roof to be heated for a indoor spa, atm they are sitting idle and end up almost exactly where i would like them. Anyone have a suggestion on a way to feed a 1" hot water pipe down a 50mm pvc pipe that has a few 90 degree bends in it? Is it a common practice or is it going to mean cutting a new hole in the main slab which makes it almost impractical
Derek
Derek
