pelle242
What type of probes do you guys use when scoping controller waveforms? Is it safe to use the ones that typically comes with the scope for ~100V ?
I think most scopes can handle 50v so when you need to scope higher voltages you MUST switch the switch on the probe to 10x. All the probes I have switch between 1x or 10x so if your scope can handle 50v on 1x (read data sheet) then 500v on 10x is likely the max. Be careful scoping these voltages I have made the ends of a few multimeter's disappear because of a small slip and if a couple fingers are involved you can be in trouble.pelle242 said:What type of probes do you guys use when scoping controller waveforms? Is it safe to use the ones that typically comes with the scope for ~100V ?
Very nice. But is sine any good on RC/BLDC motors with non-sine BEMF? I guess it's only good for induction motors. On BLDC/PMDC/PMAC motors, DTC/FOC should be used...Burtie said:
Lebowski said:...Also, it's very easy to implement very smooth torque control and braking (regen) control.
bigmoose said:Burtie can I ask which compiler you are using, and at which level of optimization?
Burtie said:Got the demo board running well enough to try a low lower dyno run,
-comparing the efficiency of the FO algorithm against the standard trapezoidal one.
Using Identical hardware to run both algorithms, and motor hall sensors with neutral timing,
This is what I found....
Slightly disappointing not to see any efficiency increase using the FOC yet.
Burtie
Burtie said:I agree the 67% efficiency figure seems low.
I would expect it to improve when I can run the motor at higher power levels.
At only one or two hundred watts, I guess the friction in the motor bearings, particularly the big skirt bearing, are affecting the results significantly.
Burtie said:Currently working on some custom hardware for this FOC algorithm which will allow me to run a lot more power in the next few weeks, so we will find out
casainho said:Hello Burtie.
Is this technology private for you sell?
Ken Taylor said:You could measure the friction losses.
Ok, good to know. If you need help to put a wiki working or git, just ask, I did just that recently to my project, so I can document it in a more structured way.Burtie said:Very early days, If ever I get anything to work well enough, I will probably post the design and offer some PCBs for sale to DIY minded folkcasainho said:Is this technology private for you sell?
Lebowski said:Burtie said:Lebowski said:The bandwidth is not determined solely by the sample rate (20 kHz), but by samplerate and loop coefficients... pity I can't see the code here
Code://******** D Control Loop Coefficients ******* #define DKP Q15(0.05) #define DKI Q15(0.01) #define DKC Q15(0.99999) #define DOUTMAX Q15(0.99999) //******** Q Control Loop Coefficients ******* #define QKP Q15(0.01) #define QKI Q15(0.005) #define QKC Q15(0.99999) #define QOUTMAX Q15(0.99999)
Hi Pedro / Olá Pedro.PowerPedro said:I would be very interrested in any working code with hallsensor setup. I searched a lot in the last days and most projects with FOC are sensoreless.
For the same purpose, I bought a cheap and new Q85 motor from BMSBattery.com. In fact I have two, one already on a testing bicycleAlan B said:You guys are having way too much fun.
I think I'll order the Stellaris TI kit.
Am looking for a cheap hubmotor for testing, something will hall sensors but perhaps damaged in some way that doesn't affect test stand use but makes it unsuitable for ebike use.
