maesitos said:
Hi snowcrow I'm thinking of building a bike with the same setup you chose, everything the same except the wheel position, I mean I'd like the hub motor to be in the front wheel.
Hi maesitos, glad to help
1) Do you think your setup will be fine for me?
Answer: The best way to choose a setup is to find a bike shop that is willing to let you take a test ride! It's always good idea to try before you buy, if at all possible!
2) Would I have enough power to start from the stops and traffic lights?
Answer: It depends on the total weight of bike and rider :? I've found it best to assist with some pedalling for a dead stop. Your system will draw a lot loss power from the battery pack and will give you greater range
3) I'm thinking of buying a 48v 15AmpH, do you think I'll handle the expected range (16miles, with a bit of margin... 2 miles or 3 miles in case I'd choose an alternative route or something).
Answer: If you're planning for no pedalling and lots of traffic lights, a 15aH battery is not going to be enough
4) Is the start powerful with no pedaling at all?
Answer: Not really! It's slow to get up to speed from a dead stop without any pedalling :|
5) What's the speed you reach with no pedaling at all? (as you can see my intention is not to pedal).
Answer: Crusing speed is about 25mph on flat pavement with no wind at 250lb total weight.
6)Do you get braking battery regen with your controller?
Answer: No, the stock controller that comes with the hub doesn't have regen
Other people have tried modifing the stock controller and have not been that successful :| If you want regen, it's best to buy a controller that has it already 8)
I think you will be needing something a bit bigger for the performance you are looking to get. Test ride a few bikes first before making your final choose and you will be a happy camper in the end :lol:
Blessings, Snow Crow
