kodexof731
So, I've been getting a flat tire about every other day, for almost two weeks now. Seven consecutive tires (including today), with the tear all in the same location: right at where the valve stem is patched into the tube, and is ahead of the valve stem in the direction of motion. I run Surly Extraterrestrials, 26x2.5, same dimensions as the stock tires. The bike has about 2700 miles on it, the tires about a thousand.
I've tried wider tubes, tubes with lock nuts. I've replaced the rim tape, cleaned the rim and the inside of the tire, and it still keeps happening. I talked to my LBS and they mentioned that it might have to do with the torque of the motor (65Nm); maybe the tube is being gripped by the tire and pulling the valve stem against the rim. I ride a normal commute on asphalt and I'm not rough on my tires. I've gotten flats with the stock tires but they were always a puncture, not this. Maybe it's a problem with surly tires, but any help would be appreciated, thank you! Kodi tutuapp
