http://www.helix-propeller.de/en/
Helix makes props primarily but they have been dabbling in electrics for a while now.
No recent news from Helix but some old bits:
electric paramotor infos
02.03.07:
First flight with Proton 1.1
On 23.02.2007 Richard Krüger-Sprengel does his first flight with the actual stage of electric paramotor Proton 1.1. This version of paramotor has a smaller propeller. The diameter was minimized on 1,40m.
The flight was accomplished at bad weather conditions (wind of 30 km/h).
Short facts:
Measured data on ground before flight full load:
Battery voltage: 44V
Discharge current: 176 A / 7,744 kw
Propeller: 2450 rpm
Measurement of H25F 1,40m R-S-05-2 torque 29,1 Nm / static thrust 49,4 kp
Pilots weight with harness, helmet, recovery, clothing: 95,6 kg
Engine weight: 31,9 kg
Wing: Silex M
Flight time: 11:37 minutes
19.12.2006:
Helix exposes prototype of electric paramotor on Coupe Icare in Saint Hilaire:
In the context of the exhibition on Coupe Icare Helix shows his Prototye of electric paramotor. Richard Krüger-Sprengel the developer of the
prototype has shown that electric paragliding is possible and will be the future. The greate feedback and resonace on the prototype stengthen
Krüger-Sprengel in his opininon. He is in close contact to several developer teams who are working on electric paramotors.
Richard Krüger-Sprengel is going to install a yearly meeting for electric paramotors, to have a platform for exchange of ideas and to
show inovations. For 2007 it is planned to imply that meeting into the german paramotor championship in Krahwinkel (15.-20.05.2007) to show the
state of the art to a wide audience.
Prototype Electric-Paramotor from Helix-Carbon GmbH
Thrust : - 55 kp
Overall weight: - 31,6 kg
Noise level: - 30% less compared to conventional combustion
engines (60db/A > ca. 53 db/A)
Airtime: - 15 min and more / still in test
Electric motor
Motor: - LEM 200 / Fa. Lemco
- brushes – disc / 5,5 kg
direct current
10 KW at 2.200 rpm
50 Volt at 200 Ampere
Controller: - Fa. Brusa
48 V / 500 A / 1,7 kg
Batterie:
- 14 accumulator Saft 35 Ah
Connected in series 14 x 3,6 V = 50,4 V
Lithium-Ion-Technologie
weight 15 kg
time to charge: 20 min to 2 hours
suspension rack:
- System Fresh-Breeze / modified
Propeller:
- HELIX H25F 1,80m R-LS-04-2
diameter 1,80 m
two part
spezial propeller optimized for optimal turnment
