fredo gauvino
- Joined
- Oct 11, 2009
- Messages
- 39
Hello all!
Here are some pictures of my first Ebike build !
For this project, I bought last autumn a 10 years old Specialized FSR Dual Suspension Mountain bike that was barely ever used for 250$. Its like new !
I then bought and installed an Amped Bikes's rear gear kit.
The installation went very well. I installed a torque arm.
To carry the batteries I installed a Filzer Rear Seatpost Rack PR-3 from MEC.ca, and a rear bag.
I then changed the tires to very large Maxxis Hookworms.
Then, a Planet bike 2W headlight, and some cheap fenders from Canadian Tire.
I installed only one of the cheap brakes provided and used a reed switch for the front brake.
This works so well that I will probably do the same for the rear brake as well, and reinstall my much better original Avid brake lever.
I found out that the wiring was heating so I upgraded the trailer connector to beefier 12 gage.
I am very pleased with the results !
Even with heavy batteries, the bike is very stable and safe. With its full suspension, it is very confortable on bumpy roads...
The large tires make the bicycle track like a motorcycle, and enable me to go faster and safely over holes and cracks...
I tried to hide the controller and wires in the bag as much as I can, So most people dont even realized its electric, until I go pass them...
I did not have big problem so far, except for the cheap batteries SLA that I have been given.
My plan is to use the bike to commute to work.
It's a 20 km (12 miles) ride, so I figured out that 3 12V 7Ah GEL SLA Batteries from would do the trick. with a recharge at the office.. with those batteries, max speed is around (30-32 km/h) 20 mph, as advertised.
It works, but barely ! I do pedal like a madman all trip long, but even then once I get to office, they barely have enough juice left to move the bike at all. I tried to go slower, and this way it is much easier on the batteries. but I can't help it, I have to go fast
Even with bad batteries, and cold weather, I went from a 50 minutes commute to 35-37 minutes which is an amazing improvement !!!
Even better when I get at work I dont even have to take a shower !
Another 15 minutes saved here.
And its a very beautiful bicycle trail all way round.
I love it !
Anyway, the ugly and heavy SLA pack will be gone soon.
I bought 4 large Zippy 22V 5Ah Lipo Batteries from Hobbycity, that should give me 44 Volts 10 Ah.
Yes I know, Lipo are not safe and can burn and explode and blablabla, but so can the gaz in your BBQ.
They weight 6 lbs.
This saves me 14 lbs !!!
With this battery pack the bike weight a very reasonable 52 lbs, and flies to 40-43 km/h( 26 mph ).
I hope to be able to do the round trip without having to recharge. I am currently setting up a charging station that I will be able to use outside my house, just in case that the charger goes berserk.
For the next few rainy days,
My next modifications will be :
- Lipo battery pack installation.( in foam to protect it. )
- Installation of a 7 speed freewheel with 11T from Ebikes.ca (So I can keep pedeling )
- Installation of a top mount shifter to replace the Shimano LX that interfere with the thumb throttle.
Can't wait to ride it again !
I love it !
They weight 6 lbs.
