Hi guys, I retrofitted a bench wheel board with 2 FVT 120A ESC's, Miniwiiceiver, and a 9000mAH LiPo battery. It runs fine, but has one annoying issue.
When riding around, after 5-10 minutes it will shut down, ubruptly brake the motors(and throw you running off the board), and the ESCs will go BEEPBEEPBEEPBEEP...on and on. Are they overheating? Loose connection? I disabled the low voltage failsafe. The fans are running fine and the ESCs feel barely even warm.
My ESC settings are:
Motor Timing: Low
Initial Acceleration: Low
Running Mode: Forward w/o reverse
Percentage Braking: 20%
Percentage Drag Brake: 20%
Cut Off Voltage: No protection
Throttle Limit: 80%
Throttle % Reverse 20%
Motor Rotation: Reverse
Neutral Range: 3%
Any help would be appreciated, right now I can't use it to ride around with fear of it throwing me off the board again randomly.
Motor Timing: Low
Throttle Limit: 80%
Neutral Range: 3%
