Roy Von Rogers
Hi all.
Having optained two A123 developer packs some years back, and wanting to use them in some ways, brought me to this site, and after reading many of the posts, got the E-bike bug. Also having bought on of Gary's boards and planing on building it at a later date, had an idea, but could use some advice from those in here who have a little more knowledge then I.
Since A123 cells are 3.3v and looking at how to charge, it struck me that since I have build a lot of computers, the power supply on those all have 3.3v with some hefty amperage. So, if one was to get a cascade chip, like a led chaser chip, and slow it way down where it would say hold for 5 seconds before it moved, could one use those to trigger a switch system to go from one 3.3v parallel pack to the next. ? I'm a big believer in not stuffing and would rather buy extra batteries and keep them at 80% level, to get longjevity. My first simple implementation idea was to use relays, which means a lot of relays since one would need two for each cell(s), one negative one positive. The signal from chaser chip would trigger lets say the negative relay and that relay would trigger the positive one. This would also be a safety in case a relay got stuck.
Now one could do it with an fet or transistor, but one would loose some voltage trough the device, so one would have to up the voltage on the supply, to negate the drop. And getting a single adustable 3 volt high amp power suply would also be a way to charge this way. This way one would charge the cells to the optimum 80% charge, and be sure all cells have the same voltage, for its getting charged from one source.
Need some input here to see if this idea is workable.
Roy
Roy
