Twelvebears
- Joined
- Apr 4, 2019
- Messages
- 12
Hi everyone.
Just wanted to introduce myself and say hello.
I live in Hertfordshire England and I’m a wheelchair user. My project is the progressive upgrading of the front mounted power drive I have for my wheelchair.
It’s basically a small bike front fork with a frame and brackets which attach to my chair. It uses ebike parts and a direct drive hub motor running at 48v
While it has been great fun and given me a lot of freedom without the use of my car, anyone who knows about mobility/disability equipment will know that everything cost a fortune. Yes the arguments about low volumes do have some bearing, but as I’m discovering, there is also a massive amount of profit made by selling otherwise unremarkable engineering as specialist equipment.
I’m not going to name the manufacturer involved, but to give just one example of questionable engineering, there is not connector between the hub motor and the controller, so as a friend discovered, you can’t actually detach the wheel and hub to say, change a tyre or the disc rotor, without cutting the phase cables.....
I should point out this piece of kit cost nearly £5k (that’s GBP) and yet the motor doesn’t even have Hall sensors, and is clearly using a very generic Chinese controller.
I’ve already added a second battery for additional range and a bit more weight over the front wheel for traction. The next Phase of improvements is to fit a Grin Phaserunner, v3 Cycle Analyst and sort out that wiring!
After that, replacement front fork with suspension is on the cards, probably with a different motor (either before or after I melt the current one).
I’m finding this whole area of ebikes fascinating, and this form seems like a great place to learn.
Looking forward to the journey!
