neoplasticity
I bought a 350 watt front geared hub hit from cellman about 18 months ago.
http://endless-sphere.com/forums/viewtopic.php?f=4&t=28355
today my motor just quit on me.
came home and my batteries are definitely good and my controller is getting power from the batteries.
using this
http://www.ebikes.ca/troubleshooting/ThrottleTesting.pdf
i've determined that my throttle is getting no power because when i check the leads, the voltage reads zero instead of 4 or 5 volts like it should
using this
http://www.ebikes.ca/troubleshooting/BlownMosfets.pdf
i've determined that my mosfets are good.
does anyone have a guess as to why my throttle has no power?
is this something easy to fix? if i take to this an electronics repair shop, could they fix it? is there a replacement controller that i can get easily?
using this
using this
