ABTsportsline
Hello everyone,
I'm stumped as to the issue with my e-bike conversion. When I give it either near full-throttle or any throttle under load, it makes a loud resonant frequency-type hum across the entire bike chassis. I've reached out to the kit manufacturer and after some back-and-forth with descriptions of the issues, they think the problem is with my bike. Whatever it is, I can't figure it out so I come to you.
I have an e-bike kit with a rear-wheel 350w gear-drive, controller, and LCD screen. I'm using a healthy 48v Ping LiFePO4 that reads > 53v during my testing. The kit only has about 25 miles on it and was installed on a brand new bicycle I purchased in August of 2013. The setup worked fine last summer, but I later moved (and then a cold & wet winter) has seen the bike shelved for the last several months. In the meantime, the battery has been kept indoors and checked/maintained every month.
This problem started after I pulled the bike out for the first time in 3 months. A rare nice day gave me the opportunity to go for a ride again, but the trip was short-lived. After a minute of riding, the kit completely cut out. When I got home I unplugged everything & re-attached all connections. The system came back to life, but made a loud noise. If I give partial throttle with no load (i.e. with the rear wheel elevated in the garage as in the video), the wheel turns fine. If i give more than ~65% throttle I get a loud hum. If I give any amount of throttle under load (i.e. when I'm riding the bike), it makes the loud noise. I've unplugged everything and re-attached, double-checking all connections.
I have made a video of the bike & noise: http://youtu.be/VOimXqEG8b8
Nothing has been added or modified on the bike since it's last use, and nothing is visibly changed from what I can tell. Nothing appears obviously loose. I've scanned all bolts nuts around the bike but nothing seems to be loose or shaking. Unfortunately my technical & troubleshooting background is not robust enough to go beyond here.
What should I try next? Thanks!
