Glenn_M
heathyoung said:Thats correct - solder the ONE pad you want the pack configured for. Ie. 12S
Reconfigure (MOVE) your cell taps to suit the configuration you need, do NOT solder more than one jumper or you will have smoke. Do not use that schematic. Ie. Tap 1 to cell 1, tap 2 to cell 2 etc etc Tap 11 to cell 11 - DO NOT SKIP CELLS.
OK got that - solder across one tab only.
But here's the thing - there is no 10s tab. Tabs for 11s to 16s on the top board and 6s, 7s on the bottom board.
Perhaps there are others beneath the daughter board that are not visible?
Should I remove the top board or does this mean 10s not possible with this BMS?
Thanks guys,
Glenn
