Hello,
semi-noob here
I would like to build a single hub motor e-board that tops out at 15mph and has the longest range and most torque possible… im a skinny dude and dont do any sliding or downhill fancy stuff… just 15mph is good for me…
the battery must have some kind of system where i can plug it directly into a wall
i need to buy a hub motor with the maytech style square hole mounting style... NOT THE EWHEELIN
what would the specs for this system be
TBH… just including links to the esc and battery that i should buy on aliexpress or ebay or something would be AWESOME… im also not sure if the motor above would fit the specs i need… so including a link for one of those as well would be great… but as long as it has the square insert style for mounting to the truck…
semi-noob here
