Chalo said:
RTIII said:
Chalo said:
SunRace makes an 8-speed cassette in 11-40 that I've seen listed online for as little as $14. Even at twice that price it would be a swell bargain. It's called CSM 680. My shop carries the 9-speed version for $40 retail, but none of our distributors carry the 8-speed one.
Darn, I'm stuck for the moment with only 7 gears in the cassette...
Cassette? Or freewheel? They're not the same, and not compatible with the same wheels.
Yes, thanks, I'm all too painfully aware of the distinction between freewheel and freehub!
I'm right now waiting on spokes of the right length so I can complete my wheel building of a new wheel for my 27" wheeled bike - with a free hub.
The bike was fine as-was, but when adding the TSDZ2, I instantly realized I had a gearing problem because of the owner reported cadence level cut-out of the unit. ... While VERY recent rumor has it that this has recently changed - and my unit is as new as they come - it appears this mid-drive stops assisting at any pedal-RPM over 90. And, so, when I did the math, I realized this would prevent me from achieving the speeds I want / expect / need. So, having learned bicycle wheel building as a teenager (by necessity - and, while no expert by any means, I was reasonably OK at it), I boldly bought a new wheel (designed for a freewheel), complete, and figured the spokes would work out, just swapping to my new Shimano "Nexave FH-T300 Silent Clutch 130mm 36H 7-Speed" rear axle. To my chagrin, it turned out that the spokes that came with are a tiny bit too long. When relaced, ALL the spokes bottom out in the nipples just before they become taught enough to consider safe. As you increase the tautness and attempt to true the wheel, it quickly becomes clear there's no adjustment room to do so. So, I have some on order... I went 2mm short, and probably should have ordered 1mm longer than I did, but... they
should work. -shrug-
Because my bike has to serve several functions and I don't want multiple bikes, I am now investigating a change in tires (if not wheels) to something wider that can take a heavier load on our crappy streets here in Oakland while still being efficient. If I can do it on the same wheel, great, or if I can change wheels, OK, and if I have to, I'll consider, budget permitting, a frame that's a bit more modern. In the mean time, I'll be using a 7 gear Shimano CS-HG41-7 11-28T “Road & Mountain bike” Hyperglide gearset in the rear.
I'm one of those "bewildered" by all the past stupidity in the bike world's nomenclature of rim & tire size and one thing I find intriguing is how I just measured the ERD (effective rim diameter - basically the end of where the spokes belong) of my new "27 inch" rim and found it to be 621mm and I also find that that's so damned close to the 622 measure of a "700C" wheel! I measured from there and the additional sidewalls of the rim are 5mm, adding 10mm to the whole diameter, and therefore about 632. But that's NOT how the rims are measured, as I understand it, rather, they go to the bottom edge of the sidewall where the tire bead should seat, and there, the number is right about 623 - within one mm of a 700C! Yet, some say the "27 inch" is actually 630 in diameter, so... Hmmm...
(Any insights on this greatly appreciated!)
Anyway, thanks for your remarks - the community here is very warm and helpful, and I appreciate your contributions.
