greasypants
- Joined
- Mar 10, 2007
- Messages
- 98
Well I went and measured the big hill on my commute home before I decide on my bike build . It measued 9 degrees on the steepest section ( measured with plumb bob and angle tool thing). If I am correct this translates to about 16-17 % grade . I will be using 5304 in the rear on 26" wheel with 35 amp controller and and trying to decide between 72v or 84v battey set up . The hill is probably only a few hundred meters long and only a portion of it is 16-17% grade. Is it worth the extra cost and weight to go 84v or will 72v setup be able to get me up the hill , or will I have to peddle with both setups ? I plane on using 18ah nimh packs from ebikes .
Thanks
Greg
Thanks
Greg
