nutnspecial
Let me start by saying it's probably dead, but I'm gonna try and lazarus that b*tch.
//And as an edit after these replies: every bms lover can come on over and beat up on me for not having one :lol: .
Been riding on a 20s set of 25/30c 5.8ah turnigys. 3 of the packs always stay balanced very well, even with higher draws of (15c) +60 amps that tend to warm the packs a little.
The fourth pack I've been keeping an eye on because one cell gets unbalanced on discharge. (about .1v lower when cell avg is 3.7v- where I normally stop.) Upon bulkcharge @1c it comes back inline.
I tried leveling the cell with the others (charge 1s to level) when at that soc, but upon bulkcharging it shot way above the rest, which tells me it had a permanently limitted capacity, and was the weak link of the chain. So I continued to use as stated, and would watch it level up on bulkcharge.
Due to voltage drop of high draws on 5.8ah, I usually take it very easy when the average cell level hits 3.75v, as full draw can start sagging the cells below 3.5v average.
2night I saw my boosted friend after I should've been calling it quits, and rode for another couple miles past my normal stop @ ~ 76v resting 20s. I made sure not to sag below 3.5 average (70v pack) and the pack seemed fine and spunky, with a resting voltage of 71v upon completion.
I had a bad feeling, knowing the one cell had diminished capacity, and expected to see possibly 3.25 or so on it.
Well, even with light careful draws, a cell avg of 20s 3.5v tonight resulted in that particular cell ending on ~1.5v, while the rest are still setting around 3.65v.
Seems odd it got that bad imo.
I'm not really sure what happened, possibly just a bad cell cell showing itself under high load. Weird how it always charged back up with .03 of the rest though. I don't think I ever discharged the pack to 71v though.
I wonder if balance charging more would have helped, I balanced the whole pack once/twice, but have had my eye on this cell since out of the box. I don't really see how much it would've helped seeing the bulk charge to 4.1 or 4.15 always leveled them out fine, although my other 5.8 pack got slow balanced the first 10 cycles, and it keeps better balance.
Surprisingly the 1.5v cell isn't noticibly puffed, so I'm planning on clamping the pack and trying to balance the pack very slowly until levels get to 3.3v, or actually I'll prob have to use the powersupply to hit the one cell till I can run the balancer even.
Even if cell lives to see another charge, I see no way to correct whatever caused this, other than limiting draw, so the weakest cell doesn't take a sh*t.
Time will tell as I re-enlist my 2nd pack and treat it similarly. Maybe the cell was the first in the 20s, thusly getting beat up more by 15c draws, maybe it was just a crap cell.
https://www.youtube.com/watch?v=VZekeEymN-A&feature=youtu.be
