I recently replaced one cell in my LifePo4 20 amp hour pack as one cell had died after about 2 years. All the other cells maintain charge and balance at 3.4 vols storage or 3.6 volts straight off charger. I have used the pack about 600 charge cycles I would estimate.
I placed the new cell in the pack and checked the individual voltage which was 3.3 upon removing from the packaging. I charged to full and let the BMS balance.
I did about 3 rides of 5k or so and recharged after. Then left the pack alone and went on holidays. I rode the pack against after about 3 weeks idle.
The voltage was 52V. As I rode, for about 5 k, and up some hills, it started to drop rather quickly to 47volts then the LVC came in and shut the pack down.
I went back and pulled the battery apart and checked the individual new cell. The rest all were at 3.3V while the new cell was 2.5 v which is what triggered the BMS to shut off to protect the cell.
The question is, did this damage the cell at all going to 2.5V which is the LVC of the BMS?
Is this typical behaviour of a new cell that is not broken in? or is this the behaviour or a bad and faulty new cell?
The cell had not swelled and when I individually charged it, it went up very quickly to 3V before slowing down a lot as it started to take charge upward from there.
I have since individually charged this cell back to 3 volts, then placed pack back together and put back onto charger to fully charge and balance with BMS. I intend to do at least 10 more small cycles or dis-recharge only using battery for 5 k or so each time and hopefully get a proper balanced cycle out of the new cell where it performs like the other 15 do which last at least 50km before dropping below 2.8V.
