It's a fairly common failure for one or more BMS channels balancing shunts to get stuck on. This places a small but steady drain on the cells which will cause the voltage to drop over time. This can be tested by just watching the voltages over time. If a cell group is dropping, disconnect the BMS and see if it continues to drop. You can also disconnect the BMS and use an ohmmeter across each connection to look for any that have about 100 ohms showing.
Hi there
Trying to find the best place for this BMS question, this looks close (ish). I have just refurbed a few pouch cell batteries. No Q on that hoping its job done. Got to field testing a battery worked up to a four mile run (up reasonable hill) yesterday came back measured each cell,
theres is a variation in cell voltages, Not massive but being a newbie, not sure if this is normal. The batt is 10 pairs of pouch cells, all were 4.1 volts when starting off. On returning..... starting from the -ve of the batt the voltages are (in order 1,2,3 etc..... 3.89, 3.89, 3.90, 3.90, 3.94, 3.93, 3.93, 3.94. 3.93. 3.94. so overall the differential is only .05 v (
which is hardly anything now I think about it). So I'm think that's hopefully
nothing to be concerned about?
Looks like a voltage gradient between -ve end and +ve end of battery beginning to appear,
Is that normal?
All the components were used (got about 10 identical batteries v cheap, all had something wrong, but knew I that, So I did a bit of mix n match to produce 4 which
"appear" perfect). atm the battery isn't cased yet so I can keep a better eye on it, and easier if I have to do more work on it.
As a bull park
at what point would a cell voltage variation indicate a problem that needs attention?
keith
