Has anyone posted any data showing how much lower the output of the Crystalyte HS24 100mm dropout motors will be compared to the HS35 135mm dropout motors at 48V and 72V?
Thanks for the chart link. I appears that the HS24 pulls more Amps and Watts than the HS35. I wonder how the HS24 will stand up to the 72V 40A controller load which I expect to use.
I see that the ebikes.ca simulator has today added both the HS24 and HT24 motors. The HS2440 simulates out between 18% and 21% less than the HS3540. The start-up torque of the HT2425 takes a greater 24% relative hit vs. the HT3525
