So i decided it would be a good idea
( probably incorrectly, although im not sure) to upgrade the controller phase wires so i replaced the phase wires from what i think was 13awg to 10 awg thicker wires. With plans to do same to motor phase wires.
Were the wires themselves getting hot (not just the connectors, which is usually a bad crimp on a ring terminal, or a loose bolted connection0?
If the wires aren't heating up, there's not enough resistnace in them to need thicker wire to get more power thru them.
But when i connected it up to test it before i put everything back together it all turned on properly the display working fine but when i open the throttle nothing!? the motor (which is brand new) just makes a click sound but doesn't spin.
So whatever i did must have somehow damaged it?
Could just be the wrong phase/hall wire order. If the motor is different than the old one, the wiring order is probably different too.
Could be a problem inside the new motor. Does it work with the old one? (assumning the brand new motor isn't replacing a damaged / broken one)
Could be a bad connection on a hall sensor wire.
Could be some other connnection problem, since presumably the controller was disconnected from everything on the bike during the wire upgrade?
Does the throttle signal wire have the corredt voltage range on it as you move it?
Conection problems are not always visible, so you may have to test from one end of a wire inside a device all the way to the other end inside the other device to verify continuity.
If the new ocntroller is programmable, then you probably have to run the setup program for it to tell it all about your system to make it work.
So i just started researching what controller i should replace my blown one with and was looking at 100 amp 30 mosfet controller s to see if there would be any advantage in a slightly higher amp controller.
Only if your battery can handle that higher current demand, and your riding conditoins/style draw enough power to cause the controller to demand the extra curent.
Two days later i received a thanks for your perchace your product is on its way message.?
I don't know how that can even happen but I'm hoping i can use it for im keeping it.
That I don't know--you'd have to check with the techncial support for the website you purchased it on. Every ebay purchase i've ever made required that I verify my payment informaiton before I checked out, and my address, etc, so it was unmistakable that I was buying something, and I always got an email notification both from ebay that I'd made a purchase, and one from my payment method site as well, within minutes of purchasing.
Ive messaged the e bay seller and the manufacturer multiple times asking for technical specifications, installation instructions what features does the controller have? anything at alll? But nothing ?
So very frustrating.
If you link to the page for the purchase, someone might recognize it or be able to find some info based on the details on the page itself. No guarantees, but worth a shot.
