Installed new ukc1 display but not registering speed
Ksq2
10 µW
London
Anyone got any ideas? Installed a new UKC1 APT display had a sw900 before. no errors are showing but the speed isn't moving or the wattage indicators. Is this the speed sensor wire? I'm running a sabvoton SVMC72150 150A. Thanks all. Also it's UART APT protocol. Motor' qs273 2.5t 12000w.
Noticed another thing with the ukc1 display on my bike. The motor pole count can only go to 15 max, while on the sw900 the pole count is set to 32? So could this possibly be the issue?
Thanks all.
Solution
If you get no data on the display, other than things (like voltage and menus) generated by the display itself, it's likely that it isn't communicating with the controller; that is usually because of an incompatible protocol (most controllers and displays are not intercompatible). When it's not that, it's usually wiring, either incorrect or poor connections.
If it was a wrong speed /etc setting, you'd stil get a speed reading, just the wrong one. Same for watts, etc.
Here are my MQCON settings.
Solution
Yeah I don't get any speed showing while moving, or wattage. Surely if it was the wrong protocol then it would show a error 30h or 30? Also the controller has a green light. I'm currently using a ukc1 APT protocol. Asked my supplier what protocol my bike uses and they said UART. Which I don't think OMD is compatible but I'm going to swap it for a omd one and try it. Thanks for your reply.
