Near the top of the page is a dropdown to choose your location, language, money type, etc.
Or you can edit the link you use to point to the version that's in your language (that one goes to NL, or Netherlands).
Thanks. I see it now, $1,300 + $261 shipping. Looking at the below specs, if correct, this sounds about right for my needs. US link:
Info from that page (my notes in parens):
e.g. Electric Motorcycle
Vehicle weight: approx 190kg+150kg (418 + 330 pounds, my bike w/ ICE was 280kg)
Vehicle tire: Front 110/80-19 Tubeless Tire, Rear 160/60-17 Tubeless Tire (I have a 110/80-18 front and 160/70-17 rear)
Battery: 72V 8.6kWh
Gear ratio: 1:9.8 (Can't be right, I think the 1:2.5 below is correct)
Speed: 72V 140KPH (87 MPH)
Climbing: 30°@72V30KPH
Pls note that $1300/pc is CNC sample price.
More info:
Rated power: 12KW
Rated volts: 72
Rated torque: 19nm
Rated/peak RPM: 5,000/9,500 (H90 V3 is 7,000)
Controller current: 308A/385A
Reduction ratio: 1:2.5
Peak torque: 70nm (same as H90 V3)
Output shaft torque: 175nm (70 * 2.5, only slightly higher than the QS138 H90 V3)
Output shaft speed: 3,800 RPM (H90 V3 is 2,980)
Wheel torque: 610nm
Weight: 22.5kg (50 pounds)
