HypnoToad
Update:
I've now repaired the PCB and the controller now works with my 10S pack again, so now I'm working on getting my 12S pack to work.
Now I found the datasheet for the PIC chip and the analogue ins are on pins 2,3,4
I measured the voltages on the analogue ins and it turns out pin 2 voltage is directly proportional to my battery voltage; Here are my measurements:
Battery voltage / Pin 2:
40.4v (10s) / 3.657v
32.36v (8s) / 2.923v
24.31v (6s) / 2.196v
16.23v (4s) / 1.468v
8.07v (2s) / 0.731v
I imagine there is some sort of potential divider that gives this voltage on pin 2, so I may be able to raise the HVC by swapping or adding a resistor.
Are there any threads or guides on how to do this? It seems 99% of the resistors on this board are surface mount so they are a pain to read.
I'm familiar with the colour codes on thru-hole resistors, but many of the surface mount resistors are marked 1003 or 2001 or 2703 for example, does anyone know the syntax of surface mount resistor markings?
Thanks.
8.07v (2s) / 0.731v
Thanks.
