MorbidlyObeseKoala
- Joined
- Apr 6, 2018
- Messages
- 147
Hopefully a quick discussion here, basically wanted to do a sanity check on my throttle and a kill switch option. Upgrading a brushed set up to learn some basics but I understand they tend to fail in a WOT position. So I wanted a handlebar mounted kill switch.
The throttle I have is your basic twist with a voltage read out seen below. Will this handle 48V going through the key switch and would it act as a kill switch when off? Or does it need another kill switch option (probably just another red manual rocker switch)?
https://www.amazon.com/QSMOTOR-Throttle-Voltage-Ignition-Electric/dp/B07D29TPM1
Definition of line color:
1.Black wire: Ground/GND
2.Red wire: +5V DC
3.Green wire: throttle Signal
4.Yellow wire: Battery Voltage In
5.Blue wire: Controller Electric Lock, Batter Voltage Out
Second question is about what anyone recommends for an additional battery protection without BMS. Solar circuit breaker at the appropriate amperage or a beefy fuse wired in series so as to not overload the batteries. It may come down to size restriction.
A few options here: https://www.solar-electric.com/pamodccibr.html
or
https://www.amazon.com/Install-Pro-Waterproof-Inline-Holder/dp/B07LH3ZWW6
2.Red wire: +5V DC
or
