Does anyone know anything about these 30A KT controllers? https://www.aliexpress.com/item/100...16821775336528932ef997!12000032681124083!im!!
I'm linking the one from other seller but KT is selling same controller on their page, they just didn't post info for 30A one for some reason.
Here it is from KT https://www.aliexpress.com/item/100...16821784215994953ef997!12000030823269787!im!!
They have few different 30A controllers but I am specifically interested in this one because of dimensions and I don't need waterproof connectors.
I've burnt my controller by accident (genius, there is another thread) so I want to buy this one. It seems perfect as it's slightly smaller in dimensions than standard 12fet controllers, it's black and everyone seem to praise KT controllers. Problem is, I've asked both KT and other seller, and both say it doesn't have regen function. I asked if it can be enabled through display and they say it can't which I find weird.
I want to use it without display.
How would one connect to this controller for purpose of programming? What exactly would be needed in terms of interface / cable, software, mods etc? Can it be programmed through display port (5pin) and USB TTL? If true that it doesn't have regen, would it be possible to enable it by shorting certain pins? If somebody has pictures of both sides of PCB for the exact same controller, it would be awesome!
Other thing I'm worried about is if the default settings such as top speed and other are severly limited and I can't change it without display so ideally I hope it has pins that can be jumped on PCB for such stuff.
Another thing I'm wondering is if when using display, changing settings would store changes in the display or controller itself making them permanent.
If anyone has any more info on this exact 30A, 12FET 146*62*38mm size controller, that would be awesome.
Thanks!
Thanks!
