LightningRods
I’d definitely go for a wide ratio 1x.
Remus said:Greetings all,
After 8 years and just shy of 10000km the 2 chainrings that came with my Lightning Rods 2014 Small Block kit are starting to show signs of server wear.
Existing drive train is 2 x 9
I'm considering transitioning to 1 x 9 drive train with a wide ratio cassette.
I would appreciate comments and suggestions from those with some experience with this modification.
Best Regards,
Remus
LightningRods said:I can’t imagine why you’d need more than nine gears. I haven’t sold dual chainrings in many years. I’d recommend a Wolf Tooth ‘Drop Stop’ front chainring in a 1x9. Your chain drop issues have nothing to do with the mid drive. It’s 100% the interaction between the front chainring and chain. Most commonly it’s caused by a worn chainring that has turned the teeth into hooks.
Some LBS mechanics can be amazingly ignorant and cowardly. When you find a good one you have a treasure
LightningRods said:The Cyclone 3kW and 6kW motors are internally nearly identical to my original ‘small block’ motors of 2012. They have magnets mounted on the exterior of the armature and run the phase and hall wires through the same sheath. The Cyclone motors are decent motors but only work well with square wave controllers at lower rpm. At high rpm the magnets come loose and trash the motor. If you want to run a cheap 48V battery and square wave controller it doesn’t matter which you use. If you want to use a sine wave controller and/or higher voltage my IPM motors are a much better choice. The main benefit of the Cyclone is it’s planetary gear box.
LightningRods said:My ratings are more realistic. I’m going to put an XXL in a ‘66 Honda Sport 90. It’s a great motor for a light motorcycle. It is different from my three smaller motors. It has a heftier axle, bigger bearings and is slightly larger in diameter. A customer powered a 1/2 scale car with it. It’s quick!
LightningRods said:High Voltage Kits produces complete plug and play ASI controller kits for my motors. The ASI controllers are very advanced but are notoriously difficult to set up properly. Greg at HV has dyno tuned the ASIs to run perfectly and made a dedicated wire loom. (greg@highvoltagekits.com)
A new controller that I’m very excited about is the NextGen from PowerVelocity. This controller is also a very advanced sine wave, puts out 300 phase amps, and also runs at up to 130V. All of the ASI controllers are limited to 85V max so this is a big advantage. Vad at PV says that the NextGen are user tunable using the VESC Tool app. (www.powervelocity.com) I just received one of these new controllers and I’m very eager to try it out.
