Ellectrico
- Joined
- Aug 10, 2019
- Messages
- 53
DESCRIPTION:
Lightly used Ninebot g30 battery. 95-98% of nominal capacity GUARANTEED. Packs were tested before shipping.
ATTENTION, read before buying:
The battery's bms is locked so you'd have to either flash it (plenty of guides online) or remove the bms and install your own (30 minutes at most)
DOES NOT COME WITH A CHARGER
Condition: Lightly used
Connector: xt60
Cell Layout: 10 series 5 parallel
Measurements:36.5*11.8*7.3cm
Casing: Plastic
Nominal Voltage: 36V (Max voltage 42v)
Charging time: 4-5 hours
Cycle life: ~800-1000 cycles
Nominal Capacity: 15.3ah
Watt Hours: 551Wh
Ammount of cells: 50
Cell manufacturer: LG
Cell capacity: 2600 mah
Cell Size: 18650
BMS: Installed but it's locked(Low Voltage, Overcharge, Temperature, Current output and Short Circuit protection, with power equalization output)
Storage conditions: -15 ~ +35 ℃, relative humidity: 45-75%, atmospheric pressure: 86-106KPa
Use the operating temperature: Discharge: 0-60 ℃; Charging: 0-45 ℃;
Shipping is 15.50 and 2 batteries can fit in a box. For larger orders the shipping is 19.95 for up to 4 batteries in a box.
Connector: xt60
Casing: Plastic
Watt Hours: 551Wh
Cell Size: 18650
