SOLD [$75 plus shipping USA BASED] 36v 27.9aH 1004wH (lg18650mh1 3200mAh cells) 10s9p, Unused, locked bms
Los Angeles
We received 5 of these batteries. Great condition, but unfortunately they are locked, so you have to take it out of the enclosure and install your own bms, or just bypass it entirely if you're planning to use it on a low charge/discharge application.
If you're interested in buying all 5 at the same time, the price will drop to $275 for the whole lot, not including shipping.
All the specs are below:
Price: $75
Condition: Unused. Stored in a warehouse since November 2022. Kept at 50% charge and charged regularly but some degradation is expected due to time.
Manufacturer: Ninebot
Enclosure: Hard plastic and metal hybrid case.
Cell holders: Sturdy, custom hard plastic cell holders with anti-vibration and insulating gray caulk
Connector: Custom Segway-Ninebot connector
BMS: Custom Ninebot BMS. LOCKED. Needs flashing or re-installment of a new one that's non-proprietary.
Capacity: 27900mAh 1004wh
Voltage: 36v (max voltage 42v min voltage 30v)
Discharge rate: 90 amps, 135 peak (1000w continuous, 1500w peak)
Charge rate: 6 amps
Charge time: 6 hours
Cycle life: ~800-1200 full charge and discharge cycles (gentle use) or 500-800 cycles if used regularly
Amount of cells: 90
Configuration: 10 series 9 paralel
Cell manufacturer: LG
Cell model: lg18650mh1
Cell chemistry: Lithium-ion
Cell capacity: 3200mAh
Cell connection: 0.2mm pure nickel strips
---Weight---
Without enclosure: 11 lb 4 oz
With enclosure: 12.5 lb
---Dimensions---
Without enclosure: 14.5 inch x 4 inch x 2.8 inch
With enclosure: 16.7 inch x 4.7 inch by 3 inch
Battery meter and charge port are installed in the enclosure.
Does not come with a charger.
