oatnet
Ypedal said:for most of us " sane " people a bit of lube to help, but for luke's beast, dry and stiky is likely a good thing ! :lol:
KY is water soluble, so it drys to a tacky texture, unlike the waxes and oils I've seen other tire recommendations for.
I've pondered the tire slip issue, taken tires on and off a few times to see where the lube ends up. Lube ends up on the inner bead and outer rim where it is easily washed off, but not at the contact area between inner rim and bead. Even if lube gets into that contact area, the lube would have to get wetted to transition from tacky to slippery. I haven't been able to envision a way water would get forced in there with the pressure holding the bead against the rim. However, I can see how what has been effective for me with commuter bikes might not apply to race requirements.
-JD
