Do you have other examples of bikes you’ve produced?Okay so what I understand: Belt drive with these settings are impossible to get a good result. I was afraid that was the case, thats why i tried this Forum.
So a decent middrive motor with 7 gear hub and a chain with chainguard is the way? I'm building a bike for mass production
Well if you're starting from scratch, and will be designing your own frame and other parts, then all the fit and physical compatibility issues can be addressed.
This sounds real - you can space the components as you need to ensure the belt line.
I am not certain of the other remarks about the consequences of belt drives. My reading suggests a Gates belt will last for 20k kilometers. As well, I see Gates sells snubbers and tensioners for belts which suggests they may be run with lower tensions.
Bosch Active line plus mid drive will work with coaster brake:I want to build a bike from scratch with the following as mandatory. But don't know if it's even possible.
- Middrive
- belt
- coaster brake
- 5-7 gears
Why would it be impossible?Getting a ~7 speed IGH that has something like a drum or coaster brake on it isn't too hard, getting a belt drive in addition might be impossible.
Cool but this is a DIY build so we need DIY parts to do that, not a recommendation for a prebuilt bike that has proprietary parts you can't buy / fit to a DIY ebike.
I must be way behind the times, but doesn't a mid freewheel when pedaled backwards. How is that compatible with a coaster brake?
Thanks; I wasn't aware of these. It looks like the the TS could be a viable option.Not all mid drives freewheel when pedaled backwards.
Two that I know of that don't are the Bosch Active Line Plus and the Tongsheng TSDZ2 coaster brake version.
