......... in the middle, for the fan and bearingsTylerDurden said:There's a lot of space left.
Assuming I actually build this design, I need to optimise the ratio of iron to copper. As I'm not interested in anything other than continuous torque, perhaps the way to go is to limit the amps to this level at the motor end and reduce the iron volume until it reaches saturation just beyond this point? Does this make sense?liveforphysics said:Wouldn't this design have a pretty poor copper fill percentage due to the inner diameter to outer diameter difference in available space for windings?
Miles said:That's very generous of you, Luke. I think it will be a while before I'm certain enough about this to start having metal cut, though... I've got a lot of learning to do
Are you planning to learn MCAD, to create the models to use in a CAM program? If you want any modelling done, to get you started, let me know.
You mean the butt joint between the individual cores? Yes, I'm not sure how much impact this will have. I'll certainly lap the surfaces to get as good a contact as possible.liveforphysics said:Miles- Are you concerned about having a thin airgap in your back-iron?
Thanks lawson, I'll look into this.lawsonuw said:IMHO I'd use an angular contact ball bearing to take the thrust loads and an outboard deep grove ball bearing to stabilize the shaft. http://www.skf.com has some rather nice calculators for bearing life in addition to a decent online catalog. The angular contact ball bearings can take nearly as much thrust loading as a tapered roller bearing and have lower friction. Might also look at the double row angular contact bearings. A bit spendy but they'll fully support the shaft with just one bearing.
Miles said:Are there any photos of the inside of the 5kW Golden motor?
Miles said:Thanks.
Crikey!
I think that's just machining marks on the magnet back-plate.
On the first photo you can just about see the laminations running across the cores?
Miles said:Maybe a deep groove radial bearing at the pulley end of the shaft and an angular contact bearing at the other end?
lawsonuw said:For a commercial axial air gap motor, I'd expect it to use a single spiral lamination wound into a disk with the winding slots pre-cut in precisely the right spots. A pain to DIY but fast in production.
I did consider whether or not it would be possible with post machining but, it would be too difficult to create teeth with such a small diameter core, I think.Arlo1 said:I was wondering wouldnt you be able to just wrap your core material then machine it the way you want.
Another reason for picking the single rotor/single stator AF design is that it would easily allow experimentation with different rotors...lawsonuw said:Another trick axial flux motors can pull easily is mechanical field weakening, i.e. an adjustable air gap. Would be useful for a single speed drive system.
