I'm not too satisfied with all of the ebike control modes I have tried so far:
I'm in the Netherlands, and would need to have it legal (<=250 watt output power, motor only works when you pedal, maximum assisted speed of 25km/h).
Is there such a thing? Should I DIY electronics to gather all the sensor data myself, to output it to a controller? Are there others with the same problem?
I'd love to hear!
- David
- I had a foldable electric bike that had a duty cycle based control loop, and a PAS sensor: If you pedal, it goes to one of three maximum speeds.
- - It was terrible to drive away from traffic lights, as it would only respond after a second or two, and it was difficult to cycle with others.
- + It was very low effort to cycle at said speeds
- I have now replaced its controller with a Flipsky 6.7, controlling based on current, and the bottom bracket with a Bafang torque sensor (SR PA211.32.ST.C):
- + Driving away from traffic lights is great (though it's a compact bike and pulling wheelies can be a bit annoying)
- + It's lots of fun
- - It's difficult to finetune the torque curve in a way that allows maximum torque when I need it, but still respond lightly enough to maintain a certain speed. In practice I'm accelerating up to maximum speed, not pedaling for a while, and reaccelerating again
- - Needs a lot of smoothing to smooth out the individual pedal strokes the sensor reads, which makes it slow to stop applying current as well.
- I have an electric grandpa bike (Dutch brand) that has a smarter PAS sensor control loop
- + You can easily end up at desired speed
- - It doesn't assist a whole lot, and it's pretty inconsistent in when it does
I'd love to hear!
- David
