jonsully
1 W
I'm considering which motor and drivetrain system I want to employ for my next conversion (a Surly Ogre) and hoping I can figure out a way to have both cadence-based pedal-assist that supports the BBSHD style of allowing me to tailor a specific target cadence RPM that makes me happy (e.g. the motor does all the work to get me to 85rpm but doesn't surpass me there) and also support torque-based PAS for more technical / specific operations. The idea being that I might ride the bike up to a trail park and use cadence-sensing on the way there, but once I get there, switch to torque-sensing for the trail ride itself.
I'm looking at GRIN's All-Axle v3 + a Phaserunner + a Cycle Analyst 3 and, assuming I only have either the torque sensor or the cadence sensor plugged in at a time (I'd just stop and swap when I get to the park and then again before I hop on the road back home), I think this would work? My only concern is the type of PAS modes the CA3 supports. In particular, I'm not totally sure if I can replicate the "help me get to 85rpm then just help me stay there" concept that works so well in the BBSHD. CA3 docs, https://ebikes.ca/amfile/file/download/file/35/, page 22
So I guess my question is, assuming I get a cadence sensor into / onto my bottom bracket (so that the reading is my actual human RPM), is the "Basic (Pwr)" style of PAS from the CA3 able to encode the logic of "start with high/max power then once I get to 85rpm, just help me stay at that cadence by adding whatever power is necessary"?
Curious for y'all's input!
