Supreme Kay
I own a 36 volt 12ah lifepo4 battery. I was little careless when checking if the battery would fit in the triangle frame of my mountain bike. I small part of the battery cover had a cut, I can see the white paper the manufacturer use to cover the cell from the cut. The white paper has tiny cut. The battery work fine without issue. I was considering buying a heat resistant tape to cover the cut. I now have the battery round into foam to protect it in case it falls. So far these are the tape I found, I am open to any suggestion:
1. https://www.amazon.com/Foxnovo-Temperature-Resistant-Polyimide-Adhesive/dp/B00N1RHE2Q/ref=cm_cr_arp_d_product_top?ie=UTF8
2. https://www.amazon.com/Scotch-High-Temperature-1-88-Inch-60-Yard/dp/B001140TS2/ref=sr_1_8?ie=UTF8&qid=1474781201&sr=8-8&keywords=heat+resistant+tape
