GMUseless
I'm sure this has been covered a thousand times...but I need help troubleshooting a 9C / Lyen build.
I've got a 9C 2810 connected up to a Lyen 12 FET, EB212 4110 controller. I bought the controlled used, and all of the standard connectors had been cut off...so I had to re-wire all of the headers. And, the phase wires were so garbled I had to pull them completely and re-solder new ones to the PCB. I ohmed everything to make sure I didn't leave any bridges or cold joints. Anyway, everything seems to check out ok, but I can't seem to get a good forward motion.
When I try the standard 'swap blue and green' wiring on the hall and phase at 48volts, I get a very slow forward motion. It's smooth, but like 60 rpms or so. The other combo's give reverse, stuttering, or lock ups. The one that does run reverse...seems to run very fast compared to the slow froward one.
I was working on the impression that every hall combo should have one could phase combo...so I've only tried the six phase combinations. Do I need to try other hall combos? Do some of these 6 valid hall / phase combo's in fact run slow?
The throttle out of the controller is 5 volts...and the throttle is returrning a good signal from what looked like 0.75 to 4.4 volts (it was hard to tell since I tested it all with two hands...didn't have any clips handy.)
Being used, I wasnt sure what program was in it, so I reprogramed it using XPD. I set the Hall angle to AUTO. Could this be a problem?
Any ideas on troubleshooting this one?
