wineboyrider
For sure, but I was wondering if the 50v cellman pack is compatible with the bafang 48v system out of the box...
full-throttle said:$50 for XT cassette and $30 for XT chain from CRC is not expensive. You could save a few bucks by going SLX, but what's the point?Kepler said:So from what I have read, it looks like I will need to get Dyna-Sys 10 speed cluster and matching Dyna-Sys chain also. This is becoming an expensive learning curve.
Have a look at SRAM XX1 cassette RRP
Any 10sp chain/cassette should work
Will 10sp chain even fit on Bafang chainring?
It doesn't matter what size the front ring is. Get Zee instead of XT since you don't have multiple rings up front. It will work slightly better.mushymelon said:I would like to run an xt shadow+ 10spd derailleur, can you use a 11-36 cassette with 46 - 48 chainring without having problems in lowest, highest gears?
As long as the ring is ~2mm thick or less.mushymelon said:Will the bafang chainring work with a 10 speed chain?
Yesmushymelon said:Will a non dyna-sys chainring work with the xt dynasys stuff?
Now you're asking too much :lol:mushymelon said:What top speed can I expect with a 44 to 11 with a 750w at 50v cell man batt?
full-throttle said:+1PaulD said:You can use a 10 speed shimano rear derailleur for 9 speed if you use a SRAM 9 speed shifter.
Great, another neophobic..coachstevo said:You're talking about the dynasys crap
Quoting Sheldon's site, nice.. Was he even alive when Shimano introduced Dyna-Sys??
Have you even used it?
Cause in 18 month of riding and racing I'm yet to experience a single chain drop or even a mis-shift. Unlike 9sp stuff.
mushymelon said:wineboyrider said:What are the lvc issues for the controller based on the 14s cellman battery?mushymellon wrote:What top speed can I expect with a 44 to 11 with a 750w at 50v cell man batt?
I don't follow sorry.
I was asking how fast my bike would go if i bought a bafang 750w and ran through a 44t chainring to an 11T
But I imaging there would be no issues with the battery if you had it setup custom?
wineboyrider said:For sure, but I was wondering if the 50v cellman pack is compatible with the bafang 48v system out of the box...
Yeah, we need to get Bafang to offer them. I suppose I should paint them ivory to match the bike.Warren said:greenspark,
You need to put some chrome steel cranks on there. The flat black alloy cranks look really out of place.
http://www.jbimporters.com/web/checking_product_description.php?part_number=22030
