Speed MD
Regardless if the bafang BB is hardened or not( the cyclone square taper bottom bracket is hardened after all ) it will not be as strong as an ISIS bottom bracket because the outer diameter of the shaft is a lot larger and stronger on the ISIS then on the square taper. Many people with the stock GNG and cyclone square taper bottom brackets have bent the shaft with little hard offroad use, hence why the ISIS BB is so popular with heavy offroad users with the cyclone and GNG kits.
This is not close to the gng bb. It looks to me so far as much better than the isis stuff also. It is much better supported and hardened than your average bb. Cyclone stuff is not close to the quality of this kit from what I have seen
