SplinterOz
I have one of the small KLS6025S and a larger KLS7250D.
I was able to bench test both of them with the Colossus motor, consider it a torture test.
KLS6025S test
KLS7250D test
After auto setup the motor just worked simple wiring simple setup.
HOWEVER with 28 motor pole (Kelly setting) it seems to be only able to spin to 2200 RPM.
Also I have a question have you guys measured the 12v output from the controller? It seems that both of mine only put out about 10volts, not enough to drive the relay/contactor.
KLS6025S test
KLS7250D test
