Wapous said:
It is interesting to read this article on the Edrivenet.com site
Among other things it is written this:
"September 2021: Bafang has sued Tongsheng for patent infringement. Bafang has won this lawsuit, therefore the Tongsheng TSDZ2 officially can’t be sold on big platforms like Aliexpress and Amazon anymore. Because of this, it can be hard to find sellers of the Tongsheng TSDZ2 on these platforms. Sellers on Aliexpress and Amazon now don’t use the official name anymore to avoid getting their listings removed by the platforms."
https://edrivenet.com/tongsheng-tsdz2-vs-bafang-bbs02/
Very good writing in edrivenet.com about the differences between bafang and TSDZ2. Thank you for shearing.
So sad as TSDZ2 is such important technology for ebikes, Bafang lags behind and decided to make only available the torque sensor on expensive models (integrated motor).
We really need accessible technology, and not locked one that is only to protect the business models of expensive brands.
I really hope we can keep buying TSDZ2. I just built a bigger display, with the same size OLED display as SW102, that works for TSDZ2 but since the firmware and hardware are OpenSource and DIY, it is future prof that can be adapted for future motors:
dameri said:
"September 2021: Bafang has sued Tongsheng for patent infringement. ....
The only similarity between Bafang and Tongsheng I can think of is the bottom bracket mounting.
When the sue was about that, then I fear for the future production of the Tsdz2.
I've decided to upgrade my Winther Kangaroo Luxe Cargo bike with a TSDZ2 250W 36V coaster brake model with a 48V battery and XH18 display. I intend to flash it with emmebrusas 20.1c later on. I have a couple of questions and doubts which I was hoping anybody could help me with:
1. Does anybody know of an upgrade to the Winther Kangaroo Luxe with a TSDZ2?
2. Originally I had planned to install the 350W motor but that would mean it wasn't road legal in Denmark. I have read that the only difference between the different models (250W, 350W, 500W) is a setting and nothing to do with any electrical components, is that correct?
In that case i could buy the 250W and upgrade if desired.
3. I have read on a forum that it's best to combine the 36V motor with a 48V battery as that gives it more power, is that correct?
4. Does it make sense to fit it with a hand break sensor since i have a coaster brake on it? It's a hydraulic brake. Is it even possible with the XH18?
5. The battery would be placed app. 1,5m from the motor, that shouldn't be a problem correct?
6. I would like to hear if anybody sees an issue with mounting it on the frame? I'll attach some pictures.
7. Can anybody confirm that emmebrusas OSF works with a coaster brake motor?
I appreciate all the feedback and advice I can ge
36v motor with 48v battery gives higher cadence (beyond 80 rpm or so), so yes, it gives higher power, but only when you pedal fast. Torque remains the same, just that you can pedal faster and still have torque from the motor (IIRC). If you pedal slower and want high power, IMO you should get a 48v motor with 48v battery. Out of the factory, only 36v motor is available with 250w rating - using 48v battery means that you'll have to pedal fast to get that additional power. 48v motor is only available with 500w/750w rating I think. Stock firmware will refuse to work with "wrong" voltage, you need to flash opensource firmware immediately to use this "mismatched" combination. Opensource firmware allows you to set power limit, so you can put 250w limit and theoretically make it road legal.
no problem - just need to make / solder a wire extension.
Hello everyone.
Not sure this has been solved over the last months (I have a huuuge backlog on this thread).. but today I sketched a cap for the second plug of the speed sensor, that remains exposed to environment.. the black tape does not last long so I decided to 3D print my own solution.
Let me share it with you in case you need a working solution to protect the exposed plug, of course you need a 3D printer.
Casainho, please see if you want to put the STL in the main wiki for wider audience.
Thanks
View attachment Cap speed sensor cable TSDZ2.zip
thineight said:
Hello everyone.
Thanks
Yes, please add to the wiki.
I'm afraid I'm not able to do that, I'm not that skilled with github :roll: .
Sorry, can you do that in the proper section?
Te cap fits with a "click", but perhaps printed at 99% scale gives a tighter fit.
I just installed the second unit of the DIY OpenSource display on my mini cargo bike with TSDZ2:
Done, at the end of main page.
I did finish the configurations menus. Next week I will be using this firmware on my EBikes and if all goes well, I will make a release and I will document the build process for the display, as also update the TSDZ2 wiki:
2: You can order any power. I added a 250W sticker on mine just in case.
4: No need to add a hand break sensor for you. You may adapt the sensor to any moving part on the coaster brake, not sure how it's work.
5: no pb.
6: verify you can reroute the black cable to upper the pedals axe, it may interfere with the motor here.
Pictures of my 5 months old baby, while we do our daily ride on the mini cargo bike with TSDZ2 -- sleeping at the end.
I am being testing the display and the screen data on the display, is almost invisible against the sunlight - my only hope is that this OLED displays get better over time.
I am updating the website documentation and I am proud of what we got so far. I am all for repairing and reusing and that are strong advantages for me, reusing the knowledge, technology and electronic components over different devices and in time, making this future prof.
https://opensourceebike.github.io/
Hi guys,i replaced my old tsdz2 for a new one after riding to long with shitty bearings, damaging the pass ant torque sensors on the way.
After about 1000km the new motor somtimes suddenly stops supporting making a strange noise as if it runs freely, (could it be running backwards?) trembling a little also and then just stops completely. At first stop and start pedaling was enough to make it go again but its getting worse. Tried putting it in a low gear pedaling fast today and it started to work again but that coold be coincidental. Changed my old vlcd5 for the new one but that doesn’t help. Before i take the whole thing apart, does anybody has a clue whats going on here.
I planned to follow these guide today:
"How to improve motor heat dissipation"
https://github.com/OpenSourceEBike/TSDZ2_wiki/wiki/How-to-improve-motor-heat-dissipation
But it looks like my assembly is not identical?
Ofcourse it isn't, because you have dismantled the wrong side of the motor for the first 7 steps.
The side you are showing are the optional last two pictures on the "how to" step 8, to illustrate a bit more cooling by shortening the plastic cover.
I really ask myself, if it is wise that you do such a modification.
There are easier methodes to improve the heat dissipation by just filling the gap between motor and case cover with conductive pads as Wpenner did here.
Hello, in the github.com/OpenSourceEBike/TSDZ2_wiki I can`t find the firmware for the motor anymore. I want to run the motor with the SW102 display but the link https://github.com/OpenSource-EBike-firmware/Color_LCD/releases says error 404!
Yes, the SW102 is not supported anymore. The only display is this OpenSource one: https://opensourceebike.github.io/
If you really prefer SW102, then look at the others threads that have firmware for it.
LeftCoastNurd said:
looks like there's updated SW102 stuff here,
https://github.com/anszom/SW102_LCD
Yes, and I really like the graphs:
I have already flashed the SW102 display to version 0.19.11, I just need the firmware for the Motor. Also in the aktuell projekt with the new Display the motor firmware is not available. (I think the motor software hasn't changed)
Ok, I did understand just now. Got and get it at regular link, should work now.
Thank you link is OK now. There is just one thing: The new display firmware (see the post above with the bar graph) is also not available. Can you also check this?
