electroriderIT said:here we go! I calibrated again in a more scientific way
here the results...what do you think?
But SAME BEHAVIOUR of the pedals!!!
I CANT GET RID OF THIS:
[youtube]y4ScIMUBOTk[/YouTube]
as Other informations that may help you or CAsahino himself to help me..is this...I don't have idea if the values recorrect when I make the pedals rotate without weight:
[youtube]09XU7NCepi8[/youtube]
HELPPPPPPPPP
skestans said:It’s a big gap between 10 and 45 and 70. I’d suggest using weights in between these values and getting rid of the 5kg measurement as it’s too close to the 6kg.
Whatever value you get is what you put into the firmware. Everyone has widely different values and that’s why calibration is necessary. There isn’t much point in comparing values across units.
lumr002 said:For TSDZ2 with OSF V1.1 and 860 display.. can anyone help?...I do have a problem with the power. The motor PAS will not work when I pedal. The display shows human power when I pedal but no matter what power level I select, the motor power shows zero. When I apply throttle power (with no pedaling), the motor powers up and moves the bike. If I then start pedaling while holding the throttle, the motor starts assisting and I get a readout on the motor power and everything works fine. I can release the throttle and the motor continues assisting BUT once I stop pedaling and human power drops to zero, the motor assist will not come back on until I engage the throttle again. I tried adjusting the distance between the speed sensor and magnet and even removed the speed sensor but it was not the speed sensor.
Any recommendations on how to fix this?
For a 36v motor the battery should be less than 42v. Maybe get it down to 40v and try again just in caseKasheftin said:Anything else I can do before sending the bike to the nearest city service center?
Love it, congrats on your build, looks greatAntoneo said:Hi everyone, glad to be here, you very much helped me in hard install process of this engine to my full-suspension Kona Coil Air 2012 :thumb: I have read all 347 pages and make right conclusion how to be in my situation..
And my bike is just reborn with this modification, as i expected!
I'll be glad to answer any questions and share information, don't be shy, i like new people.
Thanks for this thread
Thanks for sharing and nice building. However I think that battery is not that beautiful on that place, because is to big compared to the tube of the frame. If you are planning such long trip, then you should install our OpenSource source firmware that improves the motor efficiency and so you can use a smaller battery or have more range with the same battery.Antoneo said:My 36th birthday was yesterday and i am full of positive emotions which i like to share .
Development of v2 has just started and it is not yet known, if that is even possible, when there may be a working version.Akita said:Is there a corresponding program for TSDZ2 motor controller v2 ...(JavaConfigurator.jar)
Have seen that new firmware is being worked ...
Elinx said:Development of v2 has just started and it is not yet known, if that is even possible, when there may be a working version.Akita said:Is there a corresponding program for TSDZ2 motor controller v2 ...(JavaConfigurator.jar)
All FW versions for v1 have the same origin, so does the java version for stock displays too.
The development of such a version will therefore take even longer.
So you have to be very patient or willing to contribute with programming.
Akita said:It would be good if there was a thread where only the development of now software for TSDZ2 motor controller v2 is available so I do not have to look for information.
Thanks!Waynemarlow said:Akita said:It would be good if there was a thread where only the development of now software for TSDZ2 motor controller v2 is available so I do not have to look for information.
https://endless-sphere.com/forums/viewtopic.php?f=30&t=111287
Akita said:......a thread where only the development of now software for TSDZ2 motor controller v2 is available so I do not have to look for information.
I don't want to be rude, but are you reading the complete answers you get?Akita said:.....
Exactly what I was looking for.
Elinx said:Akita said:......a thread where only the development of now software for TSDZ2 motor controller v2 is available so I do not have to look for information.I don't want to be rude, but are you reading the complete answers you get?Akita said:.....
Because again I linked earlier to V2 FW development here, when I answered you.
Again you have missed that, I think.
No help of the engine? How do you test the tsdz2? :wink:Akita said:Tested my new TSDZ2 v2 36v ... the display showed 5 bars out of 6 for the battery. No help from the engine.....
I have a hill and there were no problems to the store.Elinx said:No help of the engine? How do you test the tsdz2?Akita said:Tested my new TSDZ2 v2 36v ... the display showed 5 bars out of 6 for the battery. No help from the engine.....
36V is just a nominal Voltage for calculating (sort of average value)
A just fully charged 36V battery in good condition measures 42V and can be drained to about 30V.
If you start the display, the controller started too, so you battery draines also. How much depends again of the condition of it.
More important is the distance, you can go with a full charge and working engine.
What was the speed you are going downhill?Akita said:.....
....On the return trip also a hill but without the help of the motor.
.. Tried ECO, TOUR, SPEED and TURBO.
No difference, Same as OFF.
A short hill down and then on level ground.Elinx said:What was the speed you are going downhill?Akita said:.....
max speed of the v2 controller is 25km/h
Above this the engine give no help anymore.
