richdeloup
A dash of white rum in the vent hole and 'voila' a refreshing drink, shaken not stirred at the end of your ride 8)
spinningmagnets said:The Rad Rover fatbike on Indigogo is using a Hengtai rear geared hubmotor, and the retailer is oil-cooling the hubmotors. We''ll have to keep an eye on them to see how it goes.
Motor: 6T upgrade MAC from cellman
adding oil cooling to the hub:
17x26x7 seal rings
engine sealant
90ml of shell diala s2 insulator oil
small update about oil cooling. the shaft seals are tight, the side covers are tight, but i did not manage to completely seal the phase wires. There are always a few drops getting out.
I'll try using very thin silicone for sealing the shaft next. The used oil is Total Isovoltine 2 insulating oil. Very thin. Still eats about 150W more at 60kph now at no load :/. But Temperatures are very low now. Amazing how much effect this has. 3kW continous input power are not a problem anymore. I never reached more than 90°C after this mod.
Oil volume was ~110ml
The oil cooling is no experiment. It was planned in the first place, but I wanted to test how much difference this does, so I drove around without oil for some days. Shell Diala S2 oil was exactly designed for such purposes
As efficiency is quite low when climbing 15%+ hills, I think about adding a BBS02 750W middrive to help the MAC a bit on steep hills.
a bit disappointing but good for a commuter. I have 3kkm on the clock and the clutch still holds up...pulling 4kW peak.
the 6T does 50kph when the battery is almost empty (42V). The 8T would only do ~42kph with such little voltage of an empty battery. Too slow for town traffic.
I see no advantage in using the 8T. I had a 10T MAC at 74V before. Performance is the same. Both systems draw around 4000W.
But handling voltages >60V is not legal without special design and education in Europe. And I found no fan-less charger that is like the HLG240. The others i found are low quality and/or expensive. That's why i went for 48V (54V fully charged).
Justin_Le said:On the subject of sealing, back when I was a lot more excited about oil fill we spent a lot of time looking into bearing isolators rather than physical shaft seals. This is a clever active technique where you have spinning baffles almost that keep deflecting water back out of the motor and keep deflecting the oil to stay in, and it does it with no additional drag(Large dia. rubber shaft seals do not spin very freely!) and it intrinsically allows for pressure equalization inside and outside the hub. Have a look:
http://www.inpro-seal.com/en_US/system- ... rotection/
[youtube]hET1JLpbTfM[/youtube]
They seemed like the ideal solution but unfortunately samples are $$$ and when we looked at getting production volume quotes of units sized for a hub motor application, the BOM cost of the bearing isolators was more than all other motor components combined.
burningwings said:I am going to use soybean oil in my 3540 motor . Safeway vegetable oil. $5 for two quarts. This is the oil used in high power transformers. Tested all over the world . No toxic (food grade). In case it leaks will do no harm to pets or people ! Put some in the freezer it did not freeze solid. Had the consistency of Gasoline. Oter vegetable oils frooze hard.
macribs said:This might work well for sealing the hub, it is industrial strength solution and seems like it would prevent leakage.
http://www.inpro-seal.com/en_US/technical-resources/multimedia/?ID=230
Andytheswede said:macribs said:This might work well for sealing the hub, it is industrial strength solution and seems like it would prevent leakage.
And this has been discussed and tested successfully by several members of this forum?
Malloot said:Wouldn't the coolest (pun intended) way of doing this be using a refrigerant, make it about a quarter full with a refrigerant that evaporates at around 20 degrees Celsius. That way it will take allot of heat from the stator when evaporating and will then slowly condensate on the shell. This would probably give a much higher conduction of heat then a oil would give. No idea if a non conducting refrigerant exists but will try to figure that out.
