Joppo said:can i use semi synthetic motor oil (API SL/CF,ACEA A3/b3) for coolant in my motor?
That should work. I'd use the lowest viscosity you can find.
fechter said:Joppo said:can i use semi synthetic motor oil (API SL/CF,ACEA A3/b3) for coolant in my motor?
Joppo said:this is a huge upgrade for me and my bike, i dont understand all the negativity with oil in hub motors.
if u got the tools and know how, its not hard to get a good seal.
levleon13 said:just researched the topic , and understood that oil cooling is irrelevant when theres ferrofluid solution . does anybody know how good should be the side covers sealing when filling ferrofluid ? they say only on very high speeds this liquid start to squeez out .
Ohbse said:levleon13 said:just researched the topic , and understood that oil cooling is irrelevant when theres ferrofluid solution . does anybody know how good should be the side covers sealing when filling ferrofluid ? they say only on very high speeds this liquid start to squeez out .
Yes - Side covers do need to be sealed when using FF. Absolutely agree than FF has almost entirely displaced oil cooling, It's *much* less messy.
Ohbse said:Remove the cover using a puller or one of the other home brew methods, make sure to retain the original cover index to the hub, use a razor blade to scrape all of the mating surfaces clean and smooth. Debur with a small file if there are any protrusions or casting inconsistencies. Clean with isopropyl alcohol. Apply a *thin* bead of silicone gasket maker, any automotive store will have something suitable. Use a glove to smear this into an even *thin* layer on both mounting surfaces and then replace the cover. Twist slightly in place to ensure a clean seal, align and replace the screws. You should have a small amount of consistent squeeze out around the circumference of the hub. Don't use too much, a little dab''ll do ya. Repeat for the other side.
While you have the brake side cover off I would recommend using a 1.5mm or 2mm drill bit drill THROUGH one of the disk rotor bolt holes, you can use this to fill the hub. Make sure to clean up when you're done and use loctite Blue or similar on your bolt threads to ensure no leaks there.
I use castor oil in my H4040 motor. No odour like ATF and much easier to clean away any leaks. The process to seal the side covers is described a few posts back. Be sure to use an oil resistant silicone sealant.FlyingFinn said:So what do you think, if I seal the cover seam with silicone, drill a small hole and put some AT-oil inside? No need to open the motor while cooling and rust-proofing is provided easily.
Emmett said:I use castor oil in my H4040 motor. No odour like ATF and much easier to clean away any leaks. The process to seal the side covers is described a few posts back. Be sure to use an oil resistant silicone sealant.FlyingFinn said:So what do you think, if I seal the cover seam with silicone, drill a small hole and put some AT-oil inside? No need to open the motor while cooling and rust-proofing is provided easily.
To avoid the side covers coming loose for rough offroad conditions, something I did was to use loctite on totally clean threads on the side plate screws. To do that I removed the screws when sealant had cured, and installed new clean screws with loctite.
To seal the hub motor properly you also must use the same sealant on the wire slot in the axle. I replaced my wires with thicker and more flexible wires, and smothered them in sealant before laying them back in the slot. I used heat-shrink wrap to compress the wires and sealant into the slot. Once cured I removed the shrink tape and assembled with bearing and side cover.
Obviously you must have sealed bearings. A little oil will leak out at times between the axle and bearing inner bore.
I added a 1mm breather hole near the chain sprocket. For oil fill/drain I have a M5 bolt tapped into the right side cover plate, out near the magnets. Fiber washer to seal it and bolt short enough so it wont touch the magnets.
I also have one of those hub-ring cooling heat dissipation fins. Forget the name. But highly recommend it. I pump 6500W through my H4040 and never have overheating issues.
Wow, -20 air temps! Yeah, too cold for castor. If not ferro-fluid, then you better use a mineral oil. Just a bummer because it stinks when it leaks.FlyingFinn said:Thanks for the info! Only issue with castor oil is the viscosity in cold. It can get -20C around here so best option is still to use normal Mobil1 synthetic car oil or AT-oil?
The one at http://ebikes.ca/simulator ?FranBunnyFFXII said:It doesn't overheat now because it's running at spec, but I'm overvolting it by 25% and the EBIKE sim says it will over heat.
.Since the overvolting and new battery I am doing is intended to run 30 amps over 26, and 60volts over 48, and partially intent at running extended periods of time at 30mph+. Cooling is Safe guard over requirement. It will need cooling, just not as much as other builds.
Peak output 1800 Watts, on a "1000watt"(really 1250), system. Top speed of 37mph, Some sustained 35mph road time
I don't know what the oil will do to any of the interior components. Probably nothing...but I don't know. I used ATF in a short experiment with that geared hub, but it leaked like a sieve and got on the rim brakes, etc. Intended to continue the experiment but didn't; cant' remember why. It's in the DayGlo Avenger thread somewhere, probably near the end.I'm mostly just worried about stopping leaks, and making sure the oil im looking at doesn't eat the insulation.
fechter said:If you can seal the motor cover well and use just enough oil fill the magnet gap when it’s running it might work out ok.
With a direct drive motor you don’t need to use too much oil. It will spread out when the motor runs sort of like ferrofluid.
FranBunnyFFXII said:fechter said:If you can seal the motor cover well and use just enough oil fill the magnet gap when it’s running it might work out ok.
What I'm really interested in is the liquid fill of the entire motor, as the Stator doesnt rotate to fling the oil everywhere like a crankshaft would. Rather the case rotates.
Does the force of a rotating drum with no edge to propel the liquid counteract the force of gravity?
How much of the oil is flung around?
ect. ect.
I cant find a fluid dynamics simulation to answer this question.
John in CR said:FranBunnyFFXII said:fechter said:If you can seal the motor cover well and use just enough oil fill the magnet gap when it’s running it might work out ok.
ect. ect.
Over filling creates more heat. The oil follows the rotating shell pretty well, so do it in a manner that you can experiment with different amounts of oil fill. I seem to recall from others' results that 10%-25% fill worked best, but I'm sure that varies by motor.
