So, I got a plastic box that seems to fit right. It' a little too tall- I intend to cut it down to size (for maximum ground clearance possible)
I'm thinking of drilling holes into the Plastic box and Cable tie all the components (Esc- Lipo, Reciever) to the base of the Plastic box (the side resting on the skateboard)
Is this a good idea? Will the esc get too hot and melt the Cable ties?
Now, at this moment my biggest question is what connectors do i use?
Here are the components
Here is my charger (and the chords it came with- none will fit the 4mm bullet connectors on my Zippy Lipos)
The only local option I have for connectors is 4mm Bullet connectors with case.
This
How many of these will i need? in order to connect the below listed
1. Series 6S lipo battery to the ESC
2. Motor to ESC
3. Lipo to Charger for charging (i was thinking of cutting off the XT60 connectors that came with the charger and soldering on a 4mm bullet connector in it's place- so i don't have to buy wire- is this a good idea?)
Please correct me if I'm wrong
Based on my limited knowledge I think i will need 5 x 4mm bullet connectors so that
1. 3 female from 3 bullet connectors to be used on the ESC to connect to the 3 male bullet leads from the motor
2. 1 Bullet connector (Male and female)- to be soldered to esc to connect to the series 6S lipo
3. 1 Bullet connector (Male and female)- to be soldered in place of the XT60 connector on the chord that came with the charger- for charging the lipos
Please could someone confirm whether i'm right about this? so i can go ahead and place the order for 5- 4mm HXT bullet connectors (and some heat shrink tubing)
Thanks in advance!
